Internal BPM "Project.OnChangeMilestoneOrderLine" not working properly
I am working on a customization on the Project Entry dashboard; however, I haven’t even been able to begin the customization because the base doesn’t seem to be functioning properly.
When I select “Billing Required” on a Project Milestone, and then fill out the order details, it always throws an error saying the order number / line is invalid. However, I have verified on multiple orders/projects that the order number / line is indeed valid.
I have not created any custom BPMs for project milestone, and the error persists when I disable any other custom BPMs associated with the Project BO
The Error:
Proof the Order is correct
Any help would be appreciated!
Does it matter that the SO is not open?
It does not seem to change the result when I close/re-open a sales order
Edit: I didn’t see the open checkbox. I will give that a try
Opening the line itself didn’t solve the issue, but it led me to reopen the order release and the associated project an that ended up solving the issue. I thought it was a BPM issue, but it seems it was simply a bad order I was given to test. Thank you!
You’re so welcome! Glad I could help at all. :slight_smile:
