Wayne,
One other possible solution to make it visible through Vantage is to set up
a vb form field for the vendor and customer files and have a vb form field
display the value.
Tim
Sent: Friday, January 26, 2001 8:54 AM
Subject: [Vantage] Internal Vendor & Customer nbrs
At 09:08 AM 1/26/2001, Tim Ligas wrote:
internal ID number is visible? Or any "magic key" you guys use for
debugging that will show such behind the scenes data?
Some vendor reports I mess with have a big enough speed advantage selecting
on the number rather than the ID, that I go to the trouble to run a
preliminary report to look up the numbers (plus keep a list of the common
ones.) sure would be nice to have easier lookup available.
-Thanks
Wayne
To unsubscribe from this group, send an email to:
vantage-unsubscribe@egroups.com
display the value.
Tim
>Remember that the vendor and customer id's are the two id's in the softwareHey Tim... Is there any place in the normal Vantage screens that the
>that can be changed at a later date without losing historical information.
>The system actually uses the VendorNum and CustNum fields to uniquely
>identify the vendors and customers.
-Thanks
Wayne
