Sent: Wednesday, January 01, 2014 9:22 PM
Subject: RE: [Vantage] Inventory adjustments to the 8th decimal place?
Hi Greg,
We use LotFifo costing, so I wrote one to adjust the PartFifo layers and to make them inactive. I wrote the PartBin UBAQ today and it does adjust to zero, but I am having some issues with the deleting of the empty bin.
The delete works in the BAQ designer, but not always in the dashboard.
I only let accounting do the adjustments as they are not traceable.
HTH,
Greg
Does the updatable capability do a writeback to the BOH to allow it to be set to "zero"?
Would it be too much to ask you to share the BAQ?
Bob Carlson
rcarlson@...<mailto:rcarlson@...>
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
