Hi Ernie,
I'm not sure I understand what you are asking.
Is your question about the mechanics of the combo?
Or did you want to set a default reason code for Qty Adjustments?
--- In vantage@yahoogroups.com, "Elizabeth" <gracefulthreads@...> wrote:
> Vantage 8.03.409C
> In Inventory Qty Adjust, when you choose a reason code description using the dropdown, the adapter goes and gets the reason code. How do I make that same call when instead of using the dropdown I have the field populate automatically? I can get the appropriate value in the field, but the call doesn't get made.
> Ernie Lowell
