Invoice Group Invisible
I was suspecting the same but I restarted the server.
there was no change.
Even if there is session held,it usually displays in the window associated with
group,but there is no group at all.
I tried pulling data from crystal report's Apinvoicegrp table with all fields,
but nothing is showing up.
I hope its the same table.
But then later when I tried from Vendor table I was able to display all vendor
group names in crystal report.
I am not sure what is the exact issue
Please help:
We have invoice enter group that is not showing in invoice entry. We are not able to select to post or delete this group. There is message that pops up saying "this group in currently being used" when we check one invoice in that group.
thank you
raja
We experienced a similar problem a while back. The user had accidentally put a space in front of the invoice group name and we could no longer access it. We had to go into the database (SQL in our case), remove the space and then we could use the group again. I'm not sure if you are having the same problem, but it's worth a look.
Eric
--- In vantage@yahoogroups.com, "zuhaib_akhtar" <zuhaib_akhtar@...> wrote:
> Please help:
> thank you
> raja
HI Eric thanks for the reply.
We are using vantage 6.10 with progresss SQL.
It could be a same problem but we are not able to see any group in the list.
thank you
raja
--- In vantage@yahoogroups.com, "precisionwirecomponents" <eackerson@...> wrote:
> Eric
> --- In vantage@yahoogroups.com, "zuhaib_akhtar" <zuhaib_akhtar@> wrote:
> > Please help:
> > thank you
> > raja
Raja,
Check to see if you have any hung sessions in promon. It sounds like
the person who enters your invoices may have dropped a connection while
in the invoice group and now has hung session.
Chris
_____
Of zuhaib_akhtar
Sent: Tuesday, December 22, 2009 9:15 AM
Subject: [Vantage] Re: Invoice Group Invisible
list.
thank you
raja
> Eric
> > Please help:
> > thank you
> > raja
