Is it possible to DMT into training...?
Nick, I see you posting questions about creating another database, and
the DMT question below. Note that if you restore a copy of your
database (with your company & license) into training, you can use DMT
with it - that might be your easiest route.
Brian.
Of Ned
Sent: Monday, September 12, 2011 5:01 PM
Subject: RE: [Vantage] Is it possible to DMT into training...?
No, it is not possible.
The license file is based on the CompanyIDs in the database, so you
can't use your company license to access it.
There might be a demo license you can get from Support, but I am not
sure if that is available to non-epicor partners/employees.
I thought i would ask the question here first before asking suport.
Anyone know?
On Mon, 12 Sep 2011 16:15:20 -0000
"cooner_55421" <cooner_55421@...> wrote:
Hi Carl,
>Is there a way to get the current workstation ID?
Did you find any more about this?
I see CUR-WORKSTATIONID is listed in a tech tip but...
not working on either V8 or E9 that I tried.
However... I do see a WorkstationID in my traces:
- Epicor.Mfg.BO.ReportMonitor
- GetRowsKeepIdleTime
- Epicor.Mfg.BO.ReportMonitorDataSet
- <parameter name='whereClauseSysRptLst'
........ WorkStationID ='D2003 1'
- ]]></parameter>
I'm trying to unravel a printing issue, I don't think
workstation has anything to do with my problem but now I'm
pretty curious
--- In vantage@yahoogroups.com, "cooner_55421"
> P.S.
> I checked my user setup, workstation was blank.
> I selected a workstation and saved the user record.
> When I reopen the user record, the workstation field is
>blank.
> So... something missing in my setup?
><cooner_55421@> wrote:
> > I hadn't noticed this before.
> > I just checked and Workstation was (none) when I added
>it to my client view options.
> > V8.03.409C & E9.04.506.
> > I thought this used to work...
> > --- In vantage@yahoogroups.com, "CarlH" <carl.heeder@>
>wrote:
> > > CUR-WORKSTATIONID is a valid variable (the compiler
>doesn't complain) but there is no value there.
> > > I'm now suspecting that I have to do some sort of
>call to get it.
> > > > Did you try CUR-WORKSTATIONID already?
><carl.heeder@> wrote:
> > > > > In BPM's DCD-USERID returns the current user ID.
Sure - just change db port on opening screen
> Anyone know?
> Hi Carl,
> - ]]></parameter>
> pretty curious
> Thanks
> > P.S.
> >blank.
> >call to get it.
eh, i get 4gl errors when trying. i did change the port.
On Mon, 12 Sep 2011 16:53:18 -0000
>asking suport.
> Anyone know?
> Hi Carl,
> - ]]></parameter>
>I'm
> pretty curious
> Thanks
> > P.S.
> >blank.
>added
><carl.heeder@>
> >call to get it.
>ID.
DMT is licensed by Company
does your training db have your company code ??
> >asking suport.
> > Anyone know?
> > "cooner_55421" <cooner_55421@> wrote:
> > Hi Carl,
> > - ]]></parameter>
> >I'm
> > pretty curious
> > Thanks
> > > P.S.
> > >blank.
> >added
> ><carl.heeder@>
> > >call to get it.
> >ID.
The license file is based on the CompanyIDs in the database, so you can't use your company license to access it.
There might be a demo license you can get from Support, but I am not sure if that is available to non-epicor partners/employees.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Nick
Sent: Monday, September 12, 2011 12:50 PM
Subject: [Vantage] Is it possible to DMT into training...?
Anyone know?
Hi Carl,
- ]]></parameter>
I'm trying to unravel a printing issue, I don't think workstation has anything to do with my problem but now I'm pretty curious
> P.S.
> When I reopen the user record, the workstation field is blank.
>call to get it.
