Is there a way to resize panels on a dashboard in Kinetic?
I want to resize the panels so that more data can show on the right panel. RIght now the left panel is taking up a lot of room.
You are in the edit layout mode that lets you set up panels in a grid fashion, you should be able to drag the grey edges on the border to resize them. There is a lower limit to the sizing.
If you change the mode to the “normal” app studio mode, and click each element, you get a popup in the corner that says xx%, you can set this to say 30% and the element will take up 30% of the view.
What do you mean by “normal” app studio mode? I am not seeing that. After unchecking the edit layout mode box I am unable to drag any panel.
From the Application Map tab, click on the top item and look at Layout. I think “normal” is like below while you may be in Flex Layout or Fit to Page Mode.
