Is UpdateExt updated to updater?
Just upgraded to 10.2.500.12 Noticed that in the Updatable BAQ, there is this updater object. Is this object available in method BPM? How do I use it?
using (var updater = this.getDataUpdater("Erp", "Project"))
    var ttResultQuery = ttResults
        .Where(row => !string.IsNullOrEmpty(row.RowMod) && row.RowMod != "P");
    foreach (var ttResult in ttResultQuery)
        var ds = new Erp.Tablesets.UpdExtProjectTableset();
        // Query to object mapping
            var Project = new Erp.Tablesets.ProjectRow
                Company = Constants.CurrentCompany,
                ProjectID = ttResult.Project_ProjectID,
            ds.Project.Add(Project);
            var ProjPhase = new Erp.Tablesets.ProjPhaseRow
                Level = ttResult.ProjPhase_Level,
                PhaseID = ttResult.ProjPhase_PhaseID,
                ProjectID = ttResult.ProjPhase_ProjectID,
            ds.ProjPhase.Add(ProjPhase);
        BOUpdErrorTableset boUpdateErrors = updater.Update(ref ds);
        if (this.BpmDataFormIsPublished()) return;
        ttResult.RowMod = "P";
        // Object to query mapping
            var ProjPhase = ds.ProjPhase.FirstOrDefault(
                tableRow => tableRow.Company == Constants.CurrentCompany
                    && tableRow.PhaseID == ttResult.ProjPhase_PhaseID
                    && tableRow.ProjectID == ttResult.ProjPhase_ProjectID);
            if (ProjPhase == null)
                ProjPhase = ds.ProjPhase.LastOrDefault();
            var Project = ds.Project.FirstOrDefault(
                    && tableRow.ProjectID == ttResult.Project_ProjectID);
            if (Project == null)
                Project = ds.Project.LastOrDefault();
            if (Project != null)
                ttResult.Project_ProjectID = Project.ProjectID;
            if (ProjPhase != null)
                ttResult.ProjPhase_Level = ProjPhase.Level;
                ttResult.ProjPhase_PhaseID = ProjPhase.PhaseID;
                ttResult.ProjPhase_ProjectID = ProjPhase.ProjectID;
        if (boUpdateErrors?.BOUpdError?.Count > 0)
            ttErrors
                .AddRange(
                    boUpdateErrors.BOUpdError
                        .Select(
                            e => new ErrorsUbaqRow
                                TableName = e.TableName,
                                ErrorRowIdent = ttResult.RowIdent,
                                ErrorText = e.ErrorText,
                                ErrorType = e.ErrorType
It appears this is a “shotcut” to get the UpdateExt logic. Did you check if it is still using UpdateExt as the actual Method Call?
There is nothing special inside this updater class. It just calls UpdateExt method of the specified service (business object).
