Hi, complete Epicor newbie here so bear with me! Someone on my team has asked the Job Traveler report to be amended. Currently, if a job relates to two or more “Make to Order” for example, it only shows the first Target Job in the list, but it sums up the quantity required for all target jobs. I need to amend it such that it displays all target jobs on the report. Please see below the code for the Target Job bit. Any ideas?
Welcome @DAEpicorian , have you tried selecting the Shipment Schedule option when running the report? I would try that and see if it gives you what you want.
Thank you! That option is greyed out/ not selectable for the job so afraid can’t try that!
Maybe I did not understand your question.
I assumed what you meant was that a job had more than 1 demand link to Order Releases. Is that correct or are you referring to something else?
Sorry haven’t got the lingo down yet but essentially the job in question for job traveler is making a part for 2 different other jobs which are make to order.
You can see in the image below it only shows the number for one of two target jobs, whereas the quantity (not in the picture) reflects the quantity needed for both target jobs. I need the job traveler to show the numbers for both target jobs.
Ok, got you now. The JobProd table is what holds the demand links. I’m not sure how the Target Job was put on the traveler, but you would need to bring in all records from that table to be able to show them. Not sure how the RDD and report are currently set up.
