Hi,
We have encountered an issue with the “Select All” button on the Work Queue screen. When the grid data is filtered using any criteria, the button does not correctly select only the rows matching the filtered results. Instead, it appears to select rows outside the filtered subset.
As the Work Queue screen is a critical tool for MES users, we want to check:
- Is this a known issue?
Have you observed similar behavior in other environments or with other users? - Are there any recommended workarounds?
Currently, we advise users to manually review and select rows after filtering, but this is not ideal for maintaining efficiency and accuracy.
