On Tue, Aug 2, 2016 at 4:07 PM, brandonanderson7979@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>Also, if you are issuing material manually in the main system, when you click on the bin search, if you make sure that "display all bins" is UNchecked, it will only show the bins with inventory in them. It will also show how much is in each bin so the issuer can easily choose which bin it needs to come out of to avoid going negative.</p> </div><span class="ygrps-yiv-72652068"> <div style="color:#fff;min-height:0;"></div>--Jeff & Stephanie Purvis
I'm having a hard time wrapping my head around issuing materials from multiple bins and am hoping I'm just missing something simple. We have bin A and bin B. A is where a majority of our stock is held. B is the bins for an assembly area. If we make a job for 200 parent parts and I only have 50 child parts in bin B and do an issue materials, bin B goes into the negative. I know we could then do an inventory transfer from A to B, but if that parent part has 20 child parts, we would have to check each one and then do an inventory transfer to each one that was negative. That seems like a lot of checking and if we are doing lots of jobs could end up taking up most of the day for someone. Surely there has to be an easier way that I'm missing here. Thanks.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Tuesday, August 2, 2016 8:51 AM
Subject: [Vantage] Issuing materials with multiple bins
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
for backflushing there is a whole hierarchy of where things get pulled from depending on where you have backflush bins set, and primary bins, qty on hand etc. If you get it set up right, it works ok, but it takes a little digging to understand how it works, especially because some of the help files are wrong.
If you are issuing manually, the idea is to issue the parts as you pull them. So when someone pulls a bunch from your holding area, he would issue them as he pulled them. Then you know where they came from.
It might be easier to not put the assembly areas in the system, and have epicor treat them as one bin if you don't want to do the transfers from one to the next. That depends on how you want the business to run, and what tools you can make up to run outside of the system.
Multiple bins can definitely be a hassle.
