On Oct 14, 2015, at 2:13 PM, Greg Payne gpayne@... [vantage] <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-1178676265ygrp-text"> <p>All of the flow downs are checkboxes. If a customer requests a RoHS or REACH compliant build then we flow those requirements.
We build to order, so the sales order has the compliance requirements. A bpm transfers those to the job.
The demand in the po suggestion is matched back to the job and the compliance checkboxes are transferred to the suggestion.
When a PO is generated the compliance checkboxes are transferred into a UD table pre generation and onto the PO post generation.
We have a clauses page at the end of the PO that has a statement for each compliance checkbox.
To track if an assembly can be made RoHS or REACH compliant. We don’t do the amount of banned material by weight declaration process, just compliant or not. All component material is set as Yes/No/Unknown for RoHS and REACH. A sql routine rolls those up to the assembly revision nightly so we know if an assembly is capable of being RoHS or REACH compliant.
Sent: Wednesday, October 14, 2015 1:33 PM
Subject: RE: [Vantage] ITAR
I am also interested in how you are handling REACH and RoHS?
And what is required at the PO level?
Sent: Tuesday, October 13, 2015 6:25 PM
To: vantage@yahoogroups.c om
We do ITAR, DFAR, RoHS, REACH and FAA flow downs. if you buy direct to jobs it is not hard to get the information from sales order to job to PO. If you buy to demand it takes a few more BPMs to get it into PO suggestions and then to the PO. After lots of attempts we came to a solution that gets it done.
Let me know how you buy and I will send you the routines offline.
Greg
Sent: Tuesday, October 13, 2015 5:22 PM
Subject: [Vantage] ITAR
Are there any users in this group that their company is required to follow ITAR policies who would be willing to share how they dealt with the requirements using Epicor?
Brin
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
"This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by th e Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior approval form the U.S. Department of State."
</div>
