JDBC URL syntax for Progress Openedge
You have 2 types of possible connections 4GL and SQL, the ports for
those type of connections are configured via PET (In DB configuration).
As long as SQLSquirrel will use an SQL language (ODBC) to query data you
need to use a port for SQL (ODBC).
PLEASE USE 'Reply to ALL' functionality - so I don't need to search
through all new posts in Vantage group to be able to answer your
question
regards
Grzegorz Szczepański
Dnia Tue, 26 May 2009 09:50:18 -0700 (PDT)
Steven Gotschall <sgotschall@...> napisał(a):
> Thanks Nigel, SQuirrelL is what I am trying to configure. I got it
> working now. One question, I had to use the ODBC port for my
> database and not the MfgSys port. Is this because the MfgSys port is
> only for the Vantage application and all other applications have to
> come in on the ODBC port?
> From: Nigel Kerley <nigel.kerley@...>
> To: vantage@yahoogroups.com
> Sent: Tuesday, May 26, 2009 11:21:17 AM
> Subject: [Vantage] Re: JDBC URL syntax for Progress Openedge
> I managed to connect SQuirreL to Vantage using JDBC.. Note that I
> haven't fully tested the connection though!!
> My driver settings are:
> Under "Example URL:" I have:
> jdbc:datadirect:openedge://myserver :<port>
> Under "Extra Class Path" I added in:
> \\myserver\epicor\ oe101b\java\ base.jar
> \\myserver\epicor\ oe101b\java\ util.jar
> \\myserver\epicor\ oe101b\java\ openedge. jar
> Under "Class Name" I have:
> com.ddtek.jdbc. openedge. OpenEdgeDriver
> For the actual URL for the Alias I have (for the Test DB):
> jdbc:datadirect:openedge://myserver :8370;DatabaseNa me=mfgsys
> It seems to be working but, as I said, I haven't tested it fully yet.
> HTH,
> Nigel.
> --- In vantage@yahoogroups .com, "sgotschall" <sgotschall@ ...> wrote:
> > Vantage 8.03.407a Progress
> > Does anyone know the URL syntax when using JDBC to connect to a
> > Progress database?
Does anyone know the URL syntax when using JDBC to connect to a Progress database?
I managed to connect SQuirreL to Vantage using JDBC. Note that I haven't fully tested the connection though!!
jdbc:datadirect:openedge://myserver:<port>
\\myserver\epicor\oe101b\java\base.jar
\\myserver\epicor\oe101b\java\util.jar
\\myserver\epicor\oe101b\java\openedge.jar
com.ddtek.jdbc.openedge.OpenEdgeDriver
jdbc:datadirect:openedge://myserver:8370;DatabaseName=mfgsys
HTH,
Nigel.
Thanks Nigel, SQuirrelL is what I am trying to configure. I got it working now. One question, I had to use the ODBC port for my database and not the
MfgSys port. Is this because the MfgSys port is only for the Vantage application and all other applications have to come in on the ODBC port?
I managed to connect SQuirreL to Vantage using JDBC.. Note that I haven't fully tested the connection though!!
HTH,
Nigel.
Sorry, I'll have to pass on that one.
Anyone else know the answer to this?
Nigel.
> HTH,
> Nigel.
