We are seeing some odd behavior relating to job batching and cost roll up to the main job.
Say we have main job 123, it then has a batch job of 123-A. When running the production detail report we see batch job 123-A has actual costs and a status of complete. Job 123 shows no actual costs and has a status of closed.
We would expect to see the actual costs roll up to the parent jobs. Is there a setting in Kinetic where we can adjust this? Any ideas what could cause this?
Any insights here would help us out a ton. Thanks!
Hi Jeff - can you confirm that the parts from the batched job moved back onto the original jobs? I.e. either a Job Receipt to Job transaction was manually made or the ‘Auto Receive’ box was flagged on the last operation on the batched job. If a transaction didn’t occur to move the parts back, then the costs wouldn’t show up on the original jobs.
I have also seen issues with timing - if the parent job is marked complete/closed/goes into inventory before the batched job has all transactions completed, the costs may not carry through as expected.
I can see the operation on the job is marked as final and auto receive. Looking at the manufactured receipts on the batch job I see a positive qty went to the parent job.
If this is indeed an issue with timing, how could this be corrected? Is there a system process we can run to recalculate the costs?
Fixing it is going to depend on how the parent jobs were structured as far as a demand link, the costing method you use, whether the COS Capture process has run, and potentially some other financial implications that I can’t think of at the moment.
This thread may help provide some insight: Add Labor & Burden to closed jobs
