We are modifying our job completion criteria… basically making the parameters wide open and going based on received qty and then using job close as the gate for variance resolution.
I created a BAQ to see if the system completed all jobs with received qty >= prod qty, and to my surprise there are a bunch of jobs still open. When I go to the logs and job exception tracker… these jobs don’t even exist in there.
Is there some criteria that needs to be met before a job is considered for completion that doesn’t show up as an exception?
