I figured it out. First, you need to do a return and make sure that the issue complete is NOT checked. Then, you need to go back into the job, un-engineer it and go to the Assembly. What happens is that is automatically puts in a "Pull Qty". That has to be zeroed out and that will reopen the associated operations for that assembly.
Jasper
Sent: Friday, November 14, 2003 10:00 AM
Subject: RE: [Vantage] Job issue
Yes it has changed, you can no longer enter negative quantities in the issue
screens (I can't remember if it was 5.2 or 6.0 where this changed).
The menu is now called Issues/Returns...there is an "issue" column of
buttons (Material, Subassembly, Miscellaneous) and a "return" column of
buttons (same buttons)...
The new menus have the same function, but it's perhaps a little less
confusing for the material handlers (no more remembering to put the negative
sign in, etc.)
Amy O'Malley
Manufacturing Engineer
Synovis Interventional Solutions
Lino Lakes, Minnesota
651-792-2816
aomalley@...
Sent: Friday, November 14, 2003 8:42 AM
To: 'vantage@yahoogroups.com'
As long as you issued a quantity originally you should be able to do a
negative issue. I'm on version 5.0 I don't know if this has changed.
Fredy Venczel
Sent: Friday, November 14, 2003 9:23 AM
How did you do a negative issue? When I put a negative number in
the quantity, Vantage tells me it won't accept a negative quantity?
Jasper
Jasper
sign in, etc.)
Amy O'Malley
651-792-2816
aomalley@...
Fredy Venczel
Jasper
