We have DMT version 11.2.200.16 some things have changed with being able to delete extra operation details. I figured out ECO / PartOpDtl. Can’t figure out JobOpDtl.
ECO: PartOper / PartOpDtl - SUCCESS
- Make sure to include the EcoOpDtl#RowMod with value “D” for Delete.
- Make sure to include the EcoOpDtl#IsPartOpDtl with value TRUE
- Run the import in DELETE mode.
Jobs: JobOper / JopOpDtl - FAIL
- Included JobOpDtl#RowMod = “D”; JobOpDtl#IsJobOpDtl, error JobOpDtl invalid field
- Included JobOpDtl#RowMod = “D”; JobOpDtl#IsPartOpDtl, error PartOpDtl invalid field
- Included JobOpDtl#RowMod = “D”, ran as update - no change
- Included JobOpDtl#RowMod = “D”, ran as delete - delete entire op if there wasn’t material attached to cause an error.
I am running these in test and only for 1 method / job to get it working before I fix live.
Has anyone been able to successfully delete a 2nd job operation detail with Kinetic DMTs recently?
Appreciate any direction - have several thousands of records to fix. At least the methods are fixed in live so I shouldn’t get any more jobs that need fixing.
Thanks!
Jenn
