Job Shortages
Hi All,
In normal process when you release the job , you will see job shortage which has RED DOT against parts in Job entry /Job tracker screen.
Recently , I observe that my latest job release does not show any shortages( RED DOT) even if there is real shortage of parts.
Any thought how it can be possible?
V
Is the material demand a stock part?
Yes.
I can see that material demand is available …my demand is higher than stock. Which means it should appear as RED DOT in my Job entry or job tracker screen.
V
Hi Vipul.
I have never found those dots to be consistent enough to keep an eye on them. I have some application info on them but if I recall even the application documentation varies.
This happens for me. If I un-schedule and reschedule the job, it pulls the information in correct and should then show a red dot for the shortage.
