I have an employe who uses part Locations Tab in the job tracker to find the lot number and PO numbers for Job materials.
This is quite helpful as it lists down all the materials under that job at once.
But this only work when the job is open. When the job is closed, you have to view materials under each assembly and subassembly.
Is there a better way to do this apart from having a dashboard?
Thanks in advance!
