I think you can fix your problem by adding a counter or true/false if
statement on the Material Group Line then using the group lines conditional
printing feature only print raw material when it equals 1 / false or
whatever you setup.
Patrick Winter
Sent: Tuesday, July 29, 2003 2:51 PM
To: Vantage Groups (E-mail)
Subject: [Vantage] Job Traveler in Report Builder
I am trying to recreate the Job Traveler in Report Builder. I'm able to get
all the information I need but I can't seem to get it to display the way I
want it. On the original traveler, when I print a job that has multiply raw
materials it prints out the list of raw materials and then the assembly
sequence. In Crystal, your are able to have multiply "Detail" lines
associated with each group. When I print in report builder, I get the full
assembly sequence for each raw material. So if I have 3 raw materials, I
would have the 1 raw material followed by the full operation sequence. Then
the 2nd raw material followed by the same full operation sequence. Same
with the 3rd raw material. I want to see the list of raw materials followed
by the operation sequence printed only once.
Is there a way to simulate the multiply detail groups like you can in
Crystal? Is there a better way of doing it?
Any insight would be greatly appreciated!!!
Jasper
------------------------ Yahoo! Groups Sponsor ---------------------~--> Buy
Toner for Your Printer or Fax at LaserTonerSuperstore.com-Save 55%! We have
your brand: HP, IBM, Canon, Xerox, Apple and many more for less!
http://www.LaserTonerSuperstore.com
http://us.click.yahoo.com/YmQqWC/qicGAA/ySSFAA/PhFolB/TM
whatever you setup.
Patrick Winter
Jasper
