John,
Here is the address we sent the file to dweiseth@...
Chuck
Sent: Friday, September 29, 2000 9:14 AM
To: vantage@egroups.com
Subject: RE: [Vantage] Job Update
Chuck,
Does this happen on any machine on your network, or only one or two?
PROWIN32.EXE and PROW32.DLL are both Progress files so it sounds like the
Progress runtime module chokes on something that Vantage doesn't handle
properly. (We can't blame Epicor completely if that's the case; Progress
should have better error handling.)
First thing I would check would be permissions. Can you open the linked
document on that workstation without going through Vantage? If so, then
double-check the link, especially if you use long file names and/or file
names or paths with embedded spaces.
Keep the list posted on your progress!
Steve Sanders
Delta Centrifugal Corp.
Sent: Friday, September 29, 2000 8:58 AM
Subject: [Vantage] Job Update
We have had a persistent problem for about a week now, and have not
been able to get a resolution from support. Every time we try to
update a job we get the message I have listed below. We think it has
to do with document associations, because we are able to update jobs
that do not have a MS Office document associated with the job.
This program has performed an illegal operation and will be shut down.
If the problem persists, contact the program vendor.
PROWIN32 caused an invalid page fault in
module PROW32.DLL at 0167:100bb1f3.
Registers:
EAX=04100015 CS=0167 EIP=100bb1f3 EFLGS=00010212
EBX=00000000 SS=016f ESP=0063ef28 EBP=0063ef28
ECX=c15e0ae0 DS=016f ESI=8177ba79 FS=47a7
EDX=bffc9490 ES=016f EDI=00000000 GS=0000
Bytes at CS:EIP:
83 78 08 ff 75 11 ff 75 10 ff 75 0c ff 75 08 ff
Stack dump:
0063f010 100ba484 000000f4 0063f02c 00000010 04100015 0001168f
02740000 0000018c 09840003 173f1040 00030984 00000000 018c0274
00000000 c07c0002
We have not been able to have this resolved through support. This is
urgent, can anyone help.
Chuck
(Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
Chuck
Chuck,
Steve Sanders
Registers:
Bytes at CS:EIP:
Stack dump:
00000000 c07c0002
Chuck
