Attempting to customize Job Entry.
From the Customizations Tool Dialog > Wizards > Form Event Wizard > Select Event Type (AfterFieldChange) > Tables (JobHead) > Fields (Number01) > Update All Event Code
The code it generates is:
private void JobHead_AfterFieldChange(object sender, DataColumnChangeEventArgs args)
// args.Row["FieldName"]
// args.Column, args.ProposedValue, args.Row
// Add Event Handler Code
switch (args.Column.ColumnName)
case "Number01":
break;
Yet when I go to Tools > Test Code, I get:
Error: CS0246 - line 41 (958) - The type or namespace name 'DataColumnChangeEventArgs' could not be found (are you missing a using directive or an assembly reference?)
What now?! I don’t remember any special requirement in other modules?!
