We have set the min/max levels, but I will check out the trigger as
you suggest. We did indeed start out with stock below the minimum...
Many thanks,
Nick
--- In vantage@yahoogroups.com, "Kevin Kennedy" <kevin.kennedy@...>
Many thanks,
Nick
wrote:
>work.
> In the demand warehouse/bin you need to set a Maximum for this to
> Also, make sure you increase the stock above the Min level, thenlet it
> drop below the Minimum. The trigger seems to be the event when stockBehalf
> drops below the minimum, not simply the state of being below minimum
> cheers
> Kevin Kennedy
> Of nmtaylor1969bulk
> Sent: Thursday, 2 October 2008 8:00 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] KanBan Replenishment / Material Queue Requests In
> 8.03.305K
> We are starting to play around with KanBan replenishment between
> storage bins and cell bins.the
> We have setup a stock KanBan within the MPF and we see indications
> within the KanBan bin monitor that cell bins require re-filling. We
> have also set the "Add new material record to queue" option within
> KanBan setup form which we would assume generates an instruction toin
> move materials between bins to satisfy the replenishment request.
> This bit appears not to work and we dont see any request appearing
> the material queue. We therefore have no instruction to move partsmust be
> between bins and Vantage appears not to tell us where the parts
> moved from ?
> Has anyone seen this problem or are we doing something wrong ??
> Many thanks,
> Nick
