Kinetic 2025.2 - Show Less Controls button
has anyone figured how to Keep this activated without the need to press the button? I want to have that extra space in the head of the grid. before the update it was fine but now if I want to see everything I always have to press that button.
If I don’t press the button it looks like that.
So I need a way to leave it activated.
Have you found a way to fix this ? I’m testing the new version and have the same problem on some of our apps and it’s annoying to always click
I haven’t figured that out yet :confused:
Sad Cry GIF by Piñata Farms: The Meme App
What form is this? I’ve not ran into this issue but I also don’t recognize the screen in your shots.
This can be anywhere… its basically when you load too much stuff into a panel card header bar.
You can cause this if you toss in a text-area with a large default visible row setting:
The “unfold” icon magically appears:
I’ve played with it, but I don’t think its anything that is exposed in app studio. And I haven’t found that it is a control you can bounce a property-set against. Its just an artifact of the UI.
Yeah, they’ve totally changed the header bar in 25.2. I did notice they messed up the Material Request Queue buttons down to two. Our warehouse team is not happy.
