Kinetic BAQ Designer - Error with copying Subquery
Ok, I copied a subquery into the same baq.
I changed the criteria on one of my tables…
It changed the criteria on both subqueries.
A little error in their process somewhere…
I’ll make note to not set criteria before copying a subquery. :neutral_face:
I doubt that would help.
Probably has the same guid or something.
I may try to reproduce later and see.
Copy, pointer, they basically do the same thing right? :stuck_out_tongue:
