Kinetic Control Compendium
Numeric Box
Meant for numeric entry, numbers/decimals/currencies etc. Provides validations and checks.
Property Group Property Description
Basic Id Unique identifier for the control
Basic Label Text Sets the label within the control. (Fig. A)
Behavior On Search Click :mag_right: When the search checkbox is enabled, click this to create an event to control the search. This normally predefines everything, but this one gives you a nice, “undefined_onClick” event. How neat.
Behavior On Blur Click this to create an OnBlur event for the control. On Blur is triggered when the control loses focus.
Behavior On Create Click this to create an OnCreate event for the control On Create is triggered when the control is painted to the GUI.
Comments Comments Add some developer notes to the control. These are not customer-facing and are only visible in App Studio (Fig. B)
Data Key Field Indicates that a bound component is a key field. If true, the field is enabled if there is no current record, allowing the user to select an existing record or create a new one.
Data EpBinding Bind the button to a DataView.Column.
Layout Alignment Set the alignment for the control. Valid options are Left, Center, Right. (Fig. C)
Layout Width Sets the specific width (pixels) for the control. (Fig. D)
State Personalizable If true, a user can personalize this component(hide/show)
State Customizable If true, a user can customize this component in child layers
State Hidden Hides the control from view.
State Disabled Disables the control. The control will not allow editing or focus.
State Read Only Makes the control read only so that it will not allow editing. The control can still be focused.
State Auto Focus When enabled, the control is automatically focused on creation.
Advanced Min Minimum value for the control. If the user tries to enter a value less than the min, it will auto correct to a value above. For instance, if I set a min value of 100 and I enter 1 into the control, it will add two zeroes to be 100.
Advanced Max Maximum value for the control. If the user tries to enter a value greater than the max, it will auto correct to a value below. For instance, if I set a max value of 1000 and I enter 9999 into the control, it will correct to 1000.
Advanced Step Specify the increment/decrement value. Used in conjunction with the spinners property. (Fig. E)
Advanced > Format Style :mag_right: Doesn’t work.
Advanced > Format Currency :mag_right: Doesn’t work.
Advanced > Format Currency Display :mag_right: Doesn’t work.
Advanced > Format Minimum Integer Digits :mag_right: Doesn’t work.
Advanced > Format Minimum Fraction Digits :mag_right: Doesn’t work.
Advanced > Format Maximum Fraction Digits :mag_right: Doesn’t work.
Advanced > Format Use Grouping :mag_right: Doesn’t work.
Advanced Spinners Enable increment/decrement spinners on the control. (Fig. E)
Advanced Auto Correct :mag_right: Auto correct… to what??? 42?
Advanced Disable Change Value On Scroll :mag_right: Lol, scroll didn’t work in the first place.
Advanced Mask :mag_right: Works to an extent… It will allow you to use masks to define leading zeros, number of decimals, etc., but you cannot change the separator format (like change the comma to a decimal). And if you make a decimal masked like an integer, you get a fun, giant tilde for the precise value! (Fig. F)
Advanced LabelText SearchDesc Set the label text for the search description field. Requires “Enable Search” to be enabled. (Fig. G)
Advanced Ep Binding SearchDesc Set the data binding to store the description value from the search. Format: DataView.Column. Example: ABCCode.String1_c. Requires “Enable Search” to be enabled.
Advanced Nullable Allows the value to be null. (Fig. H)
Advanced Enable Search Shows the search button. (Fig. I)
Figure A: Label Text
Figure B: Comments
Figure C: Alignment
Figure D: Width
Am I triggering anyone’s OCD with this one? :smiley:
Figure E: Step and Spinner
NumSpinner
Figure F: Mask
Figure G: Seach Label Text
Figure H: Nullable
Disabled
NumNoNull
Enabled
NumNull
Figure I: Enable Search
