I am running 2023.1.6
I have a BAQ that runs in a Classic Dashboard no issues. No Sort or Parameters.
The BAQ also runs and returns the correct result when I execute it in running the new BAQ web app.
When I create an Application Studio Wizard Kinetic Dashboard in the webapp and try to Preview or refresh the dashboard I get this message in Epicor App Server event viewer. The exception about invalid column name is for a subquery 6 layers into the BAQ. Again this BAQ executes in the BAQ Designer perfectly. Suggestions???
"The description for Event ID 0 from source IceAppServer cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Ice.Common.EpicorServerException: Invalid column name ‘Calculated_BLDueToShop’."
There’s an issue where the grid is trying to display columns from the subquery. If I recall, the fix is to go into the grid’s properties > Data > Grid Model > Columns and then delete the extra columns from the subquery. I’ll see if I can find the related thread.
