Kinetic Dashboard - Export To Excel Broken
Any idea why I’m not able to export to excel in some of my simple single grid, non-updatable Kinetic dashboards? It doesn’t work in the client or on the browser. Nothing happens when I go to overflow… and click on ‘Export to Excel’, besides an error on the F12 developer tools console.
If I select rows, then overflow and ‘Export selected to Excel’, it works.
The console tab error is:
ERROR TypeError: Cannot read properties of undefined (reading 'trim')
I opened EpiCare case CS0004892374 a week ago, but would love to find a resolution faster.
What could I be doing wrong?
Google’s AI states:
The error “TypeError: Cannot read properties of undefined (reading ‘trim’)” arises when attempting to call the trim() method on an undefined variable. In JavaScript, trim() is a string method used to remove whitespace from both ends of a string. If a variable is undefined, it means it has not been assigned a value, and therefore, it does not have any properties or methods, including trim().
To resolve this error, ensure that the variable you are calling trim() on is not undefined.
I was just doing this yesterday from a dashboard grid in Kinetic, worked fine for me. I was exporting the entire grid, not trying to select certain rows. :thinking:
Assuming this isn’t checked on your panel-card-grid > Advanced?
For what its worth… i just did it again, to test. No Error… but I also didn’t see any activity in debugger in regards to Exporting to Excel (Console or Network). The error you’re seeing may be a red herring.
I tend to ignore those TypeErrors… but that may not be the best practice all the time :rofl:
Figured it out!!! Turns out that you MUST have a grid title (mine was blank).
The error and AI response was sort-of helpful. I was looking for extra leading or trailing spaces on the column names, but they were fine. Then I noticed that the error was related to a filename, which made me think that it was something to do with the downloaded .xlsx filename. And it was - Epicor wants to use the grid title to name it, and when it’s not there, it silently does nothing.
Any suggestions on how to remove or hide extra unnecessary titles? I don’t need to show ‘Open PO’ twice. Maybe I should have used a grid instead of a panel card card. Is it possible to change it? Or do I have to build it from scratch again (setting all 18 columns manually)?
Could change the title of your grid to “Results”… would at least make it appear less redundant.
Or, “Results && START https://youtu.be/E4WlUXrJgy4” and see if they’re sanitizing inputs… :smiling_imp:
Pondering Anthony Anderson GIF by BET
Sadly, that didn’t work.
There’s at least a little more syntax to break out of the file writing and do another shell thing. I left it out as an exercise for aspiring future members of the applicant pool. :stuck_out_tongue:
I’ve been reading through @hmwillett’s control compendium (holy crap, that is a godsend. Beverages on me if you ever come to central CT!).
I thought I’d be able to have a blank title for the grid, and set the filename under Grid Model > Export Excel Settings, but it still errored in Chrome and didn’t create a download file. Kinetic Really wants a title for the grid.
I added a grid title back, and was able to download a file, but it disregarded the filename and used the title.
Best solution I found was to remove the caption on the dashboard’s main page, and set a page title.
Ahh, Application Studio…
I’m disappointed this wasn’t a Rick roll.
You called down the thunder, well now you got it… - Wyatt Earp
Edit....yikes that GIF is too big
Rick Roll Gif - IceGif
Or “summary” to be more “Classic Parity” like
Just found this, thanks!!!
Just found this as well. lol
thanks
