Hi everyone! I am working on a dashboard in Kinetic. The dashboard consists of two BAQs. The first BAQ, AllLots, shows all of the lot rows from PartLot. The second BAQ, FindLot, uses a parameter to filter the results by lot number. I placed both of these BAQs in a dashboard, then deployed it as an application.
When I run the dashboard, The BAQ parameter request comes up right away, even though I did not set the BAQ to autoload.
Is there a way to trigger the BAQ parameter to pop out only when I expand the BAQ panel that actually has a parameter?
Thanks for your time!
Nate
