Kinetic Function and BPM code isn't saving again
We’re experiencing issues with our code not saving across the load balancers or app servers again. Our recently saved BPMs and function libraries are working about a quarter of the time.
This is after you requested and received the hotfix?
We’ve had the fix applied once already, supposedly. We didn’t have this issue for the past week or so.
Your hosting says on-prem, but you are SaaS right?
tell me your site number and time with timezone when 404 happened.
Is there a way to do that securely or does the site id matter for security?
We moved to SaaS last October
Click her avatar and you can send her a message.
Do you think private message is not secure enough? you can add it ot the case and tell me the case number. also it should happen in last 24 hours, or I won’t see all messages I need
