(Kinetic) - Mass Upload of Serial Numbers using CSV
Hi All,
The outline
Problem
Kinetic based mass upload of Serial Numbers
** Screens **
All serial number selection screens.
** Method of upload
CSV File
** Records **
Anything from 20-20000 serial numbers.
** Current function **
 * FUNCTION: ImportSerialNumbersFromCSV
 * DESCRIPTION: Imports a list of serial numbers from a CSV file, validates them,
 * and adds them to a SelectedSerialNumbersTableset and SerialNumberSelectionTableset for Kinetic grid support.
try
    this.IsSuccessful = false;
    const string UPLOAD_FOLDER = "SNUploads";
    const bool ALLOW_PARTIAL_SUCCESS = true;
    // --- 1. Input Validation ---
    if (string.IsNullOrWhiteSpace(this.FileName))
        this.InfoMsg = "Error: No file name was provided.";
        return;
    var selectParams = this.InDS.Tables["SelectSerialNumbersParams"];
    if (selectParams == null || selectParams.Rows.Count == 0)
        this.InfoMsg = "Error: Input parameters 'SelectSerialNumbersParams' are missing.";
        return;
    var paramsRow = selectParams.Rows[0];
    string partNum = paramsRow["PartNum"].ToString();
    string sourceRowID = paramsRow["SourceRowID"].ToString();
    string transType = paramsRow["TransType"].ToString();
    int attributeSetID = Convert.ToInt32(paramsRow["AttributeSetID"]);
    if (string.IsNullOrWhiteSpace(partNum) || string.IsNullOrWhiteSpace(sourceRowID) || string.IsNullOrWhiteSpace(transType))
        this.InfoMsg = "Error: Part Number, Source RowID, and Transaction Type are required in the input parameters.";
        return;
    // --- 2. File Handling ---
    var uploadPath = new FilePath(ServerFolder.CompanyData, UPLOAD_FOLDER);
    var sourceFilePath = new FilePath(uploadPath);
    sourceFilePath.Combine(this.FileName);
    if (!this.Sandbox.IO.File.Exists(sourceFilePath))
        this.InfoMsg = $"Error: File '{this.FileName}' not found on the server.";
        return;
    var processingFilePath = new FilePath(uploadPath);
    processingFilePath.Combine(Guid.NewGuid().ToString() + ".processing");
    this.Sandbox.IO.File.Move(sourceFilePath, processingFilePath, true);
    // --- 3. Parse CSV ---
    var serialsToProcess = new HashSet<string>();
    int skippedFileDuplicates = 0;
    string fileProcessingError = string.Empty;
    try
        using (var stream = this.Sandbox.IO.File.Open(processingFilePath, FileMode.Open, FileAccess.Read))
        using (var reader = new System.IO.StreamReader(stream))
            reader.ReadLine(); // skip header
            string line;
            while ((line = reader.ReadLine()) != null)
                if (string.IsNullOrWhiteSpace(line)) continue;
                string sn = line.Split(',')[0].Trim().Replace("\"", "").ToUpper();
                if (string.IsNullOrEmpty(sn)) continue;
                if (!serialsToProcess.Add(sn))
                    skippedFileDuplicates++;
    catch (Exception ex)
        fileProcessingError = $"Error reading CSV file: {ex.Message}";
    if (!string.IsNullOrEmpty(fileProcessingError))
        this.InfoMsg = fileProcessingError;
        this.Sandbox.IO.File.Delete(processingFilePath);
        return;
    if (serialsToProcess.Count == 0)
        this.InfoMsg = "No unique, valid serial numbers found in the file to import.";
        return;
    // --- 4. Epicor Service Logic ---
    int addedCount = 0;
    int skippedExisting = 0;
    this.CallService<Erp.Contracts.SelectedSerialNumbersSvcContract>(svc =>
        svc.GetSerialNumFormat(ref this.ds, partNum, "", "", 0, Session.PlantID);
        foreach (var sn in serialsToProcess)
            try
                if (this.ds.SelectedSerialNumbers.Any(r => r.SerialNumber == sn && r.RowMod != "D"))
                    skippedExisting++;
                    continue;
                svc.CreateSerialNum(
                    ref this.ds,
                    partNum,
                    "", "", 0,
                    sn,
                    sourceRowID,
                    transType,
                    Session.PlantID,
                    sn
                var newSnRow = this.ds.SelectedSerialNumbers.FirstOrDefault(r => r.SerialNumber == sn && r.RowMod == "A");
                if (newSnRow != null)
                    newSnRow.AttributeSetID = attributeSetID;
                    addedCount++;
                svc.AddSerialNumToSelection(
                    partNum,
                    sn,
                    sourceRowID,
                    transType,
                    Session.PlantID
                if (ALLOW_PARTIAL_SUCCESS)
                    skippedExisting++;
                else
                    throw new BLException($"Error adding serial '{sn}': {ex.Message}");
        string outDsXml;
        Erp.Tablesets.SerialNumberSelectionTableset snSelectTS = new Erp.Tablesets.SerialNumberSelectionTableset();
        int requiredQuantity = addedCount;
        int selectedQuantity = 0;
        svc.SelectSerialNumbers(true, requiredQuantity, selectedQuantity, out outDsXml, ref snSelectTS);
        svc.ProcessSelectedSerialNumbers(snSelectTS, ref this.ds, false, out _);
    // --- 5. Archive file ---
    try
        var archiveFolder = new FilePath(uploadPath, $"Archive\\{DateTime.Today:yyyy-MM-dd}");
        this.Sandbox.IO.Directory.CreateDirectory(archiveFolder);
        var archiveFilePath = new FilePath(archiveFolder);
        archiveFilePath.Combine(Path.GetFileName(this.FileName) + "_" + Guid.NewGuid().ToString() + ".csv");
        this.Sandbox.IO.File.Move(processingFilePath, archiveFilePath, true);
    catch
    // --- 6. Return Output ---
    this.OutDS = this.ds;
    this.IsSuccessful = true;
    this.InfoMsg = $"Import complete. Added: {addedCount}. Skipped: {skippedFileDuplicates + skippedExisting} (duplicates/existing).";
    this.InfoMsg = $"Critical Error: {ex.Message}";
My current upload event
Row-update
Response from function
It basically, returns the data into the Selected Serial Numbers table (here)
But when the user selects all and hits save. It will process all of the serial numbers fine but if you went on to the second line in Drop Shipment Entry - it will upload, you select all and close the slider.. The drop shipment screen will state you’ve only selected ‘1’ serial number bascially it ignored all of the other serial numbers of which have been uploaded.
I don’t know what Epicor is doing with the SelectedSerialNumbersSvc service - I’m trying to replicate what DMT is doing..
If all else fails. I will request a CSG solution.
Someone help me before I lose my sanity.
Re-sparking — Serial Number Selection - Kinetic UX - Kinetic ERP - Epicor User Help Forum
I got this working by looping through serial numbers but it’s not the quickest. Limit is around 500 serial numbers before bugging out.
Thank you
Aaron
Does the full dataset come back from the Function? Here is what I did to do mass SN Import.
Mass SN Import documentation
Add DataView
Add Tab on Main Select Serial Numbers
Metafx-tabstrip->Data
Click the “+” sign
Enter new Page information.
Go back to the application map. You should see the new page, edit it.
Add Panel card, col, textbox, and button to the screen. You can add a grid as well for testing like I did.
Properties for the text box:
ID/Label Text/EpBinding
Key Items here is setting EpBinding = TransView.SN
Properties of the grid:
Set the GRID MODEL EpBinding = dvMassSN (the dataview created above)
Button Click Event ce_IterateSerials then sets the selected serialnumber from the grid.
Dataview-condition
Erp-function
How are you passing the aerial numbers from your grid to the Serial number selection grid? Are you using a base event to create the serial numbers?
Dataview-condition in the btnMassAddSN_OnClick event loops through the grid and calls the ce_IterateSerials event for each record.
The event ce_IterateSerials loads up a few fields with row-update and then calls the OnClick_btnAddSN (this is the Epicor event)
If you monitor network tab is it calling CreateSingleSerialNumber each time? This flopped for me with around 500 serial numbers.
To many calls to the API EndPoint..
You are seeing my reference notes, as there were a few lessons learned with that project.
Unfortunately, I am not able to confirm/test as this was implemented at my previous job.
Though we did have large receipts of 1000+ SNs, I didn’t hear of any issues when they came in.
FYI This was on version 23.1, incase case things look different.
Thank you for the feedback Ken but unfortunately, this was using the same method was prior.
This is being throttled.. Gets to around 500 and flops.
What version are you on?
Latest. 25.1.8
