Kinetic MES: Filtering Unselected Grid in Material Request Queue (Load All Records on open)
Hi everyone,
I’m working in Kinetic using APP-Open from MES Data Collection to open the Material Request Queue form.
My goal is to filter the “Unselected” grid based on a Job Number, which I’m passing as a parameter.
What I’ve done:
I’m using DataView Filter - Set to apply the filter to the Unselected grid.
The Job Number value is being passed correctly, and filtering works if the job exists in the preloaded records.
Problem:
On form load, the Unselected grid only loads around 100 records, and if the job I’m trying to filter by isn’t included in that initial set, no results show up.
Question:
Is there a way to load all records on form open, so filtering works for any job?
Or alternatively, is there a way to force server-side rendering or a custom GetRows logic to fetch the specific JobNum I want?
Any best practices or recommended approaches would be appreciated. Let me know if I need to use a REST-Kinetic call with GetRowsCustomParams or a different method.
Thanks in advance!
– Amit
Solved using below whereClause in rest
