Comparing the json files between the original customization and the new customization I created from scratch (where the export works), I found these differences.
Existing customization:
"SysCheckBox01": false,
New customization:
"SysCheckBox01": true,
From the existing line that starts with
"SysCharacter03": "{\"config\":{\"Name\":\"config\",\"Version\":\"2.0\"},\"layout\. . .
Is this part that only exists in the existing customization:
[{\"Id\":\"SugPoDtl\",\"Path\":\"/mode\",\"Value\":\"U\",\"Operation\":\"Add\",\"Index\":5}]
This is at the bottom of the whole line show below.
ChatGPT says that this indicates the POSugDtl dataview being set to updatable (??) and that might cause my export issue.
Ring a bell?
Joe
"SysCharacter03": "{\"config\":{\"Name\":\"config\",\"Version\":\"2.0\"},\"layout\":{\"Name\":\"layout\",\"Version\":\"3.0\",\"Diffs\":[],\"Operation\":\"Replace\"},\"Main\":{\"Name\":\"Main\",\"Version\":\"3.0\",\"Diffs\":[{\"Id\":\"\",\"Path\":\"/heroBar/items\",\"Value\":[{\"type\":2,\"component\":{\"id\":\"4a13f3aa-cbd8-44f1-b444-7218a19e26d3\",\"sourceTypeId\":\"erp-numeric-box\",\"model\":{\"guid\":\"4a13f3aa-cbd8-44f1-b444-7218a19e26d3\",\"labelText\":\"Total New Suggestions\",\"id\":\"numSugPoDtlCount\",\"disabled\":true,\"disableChangeValueOnScroll\":false,\"epBinding\":\"TransView.POSugg_Count\",\"mask\":\">>>>>>9\",\"keepComboBoxOpen\":true},\"parentId\":null}},{\"type\":2,\"component\":{\"id\":\"3e0669a7-85d2-4530-a188-a3d2ad48bfbe\",\"sourceTypeId\":\"erp-numeric-box\",\"model\":{\"guid\":\"3e0669a7-85d2-4530-a188-a3d2ad48bfbe\",\"labelText\":\"Total Change Suggestions\",\"id\":\"numSugPOChgCount\",\"disabled\":true,\"epBinding\":\"TransView.POSuggChg_Count\",\"mask\":\">>>>>>9\",\"keepComboBoxOpen\":true},\"parentId\":null}}],\"Operation\":\"Replace\",\"Index\":0}],\"Operation\":\"Replace\"},\"POSugg_Slider.Details\":{\"Name\":\"POSugg_Slider.Details\",\"Version\":\"3.0\",\"Diffs\":[],\"Operation\":\"Replace\"},\"POSugg_Slider.Forecast\":{\"Name\":\"POSugg_Slider.Forecast\",\"Version\":\"3.0\",\"Diffs\":[],\"Operation\":\"Replace\"},\"POSugg_Slider.Generate\":{\"Name\":\"POSugg_Slider.Generate\",\"Version\":\"3.0\",\"Diffs\":[],\"Operation\":\"Replace\"},\"POSuggChg_List\":{\"Name\":\"POSuggChg_List\",\"Version\":\"3.0\",\"Diffs\":[],\"Operation\":\"Replace\"},\"POSugg_Slider.BuyerUnlock\":{\"Name\":\"POSugg_Slider.BuyerUnlock\",\"Version\":\"3.0\",\"Diffs\":[],\"Operation\":\"Replace\"},\"POSugg_Slider.ShowGenerated\":{\"Name\":\"POSugg_Slider.ShowGenerated\",\"Version\":\"3.0\",\"Diffs\":[],\"Operation\":\"Replace\"},\"POSuggChg_Slider.Details\":{\"Name\":\"POSuggChg_Slider.Details\",\"Version\":\"3.0\",\"Diffs\":[],\"Operation\":\"Replace\"},\"POSugg_List\":{\"Name\":\"POSugg_List\",\"Version\":\"3.0\",\"Diffs\":[{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/0/width\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/0/title\",\"Value\":\"Buy\",\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/1/isLink\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/3/width\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/4/width\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/5/width\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/5/title\",\"Value\":\"Approve PO\",\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/6/erpEditor\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/6/erpEditorModel\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/7/width\",\"Value\":104,\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/8/hidden\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/8/field\",\"Value\":\"VendorNumName\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/8/title\",\"Value\":\"Supplier Name\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/9/width\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/9/field\",\"Value\":\"PartNum\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/9/title\",\"Value\":\"Part\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/10/erpEditor\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/10/erpEditorModel\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/10/hidden\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/10/title\",\"Value\":\"Revision\",\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/10/width\",\"Value\":87,\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/10/field\",\"Value\":\"RevisionNum\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/11/width\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/11/field\",\"Value\":\"PartNumPartDescription\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/11/title\",\"Value\":\"Part Description\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/12/field\",\"Value\":\"DynAttrValueSetShortDescription\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/12/title\",\"Value\":\"Attribute Set\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/12/width\",\"Value\":113,\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/13/width\",\"Value\":138,\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/13/field\",\"Value\":\"DispNumberOfPieces\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/13/title\",\"Value\":\"Number of Pieces\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/14/width\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/14/field\",\"Value\":\"XRelQty\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/14/title\",\"Value\":\"Our Quantity\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/15/width\",\"Value\":66,\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/15/field\",\"Value\":\"UOM\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/15/title\",\"Value\":\"UOM\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/16/field\",\"Value\":\"RelQty\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/16/title\",\"Value\":\"Supplier Qty\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/17/erpEditor\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/17/erpEditorModel\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/17/field\",\"Value\":\"PUM\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/17/title\",\"Value\":\"PUM\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/17/width\",\"Value\":61,\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/18/field\",\"Value\":\"UnitPrice\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/18/title\",\"Value\":\"Unit Price\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/19/erpEditor\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/19/erpEditorModel\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/19/width\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/19/field\",\"Value\":\"ClassID\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/19/title\",\"Value\":\"Part Class\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/20/erpEditorModel\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/20/field\",\"Value\":\"ClassDescription\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/20/title\",\"Value\":\"Description\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/21/erpEditor\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/21/erpEditorModel\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/21/field\",\"Value\":\"JobNum\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/21/title\",\"Value\":\"Job\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/22/filterable\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/22/hidden\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/22/sortable\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/22/field\",\"Value\":\"AssemblySeq\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/22/title\",\"Value\":\"Asm\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/23/width\",\"Value\":106,\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/23/field\",\"Value\":\"JobSeq\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/23/title\",\"Value\":\"Mtl/Opr\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/24/hidden\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/24/field\",\"Value\":\"OpCode\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/24/title\",\"Value\":\"Operation\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/25/hidden\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/25/width\",\"Value\":101,\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/25/field\",\"Value\":\"OpCodeOpDesc\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/25/title\",\"Value\":\"Operation Description\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/26/hidden\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/26/width\",\"Value\":69,\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/26/field\",\"Value\":\"OrderNum\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/26/title\",\"Value\":\"Order Number\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/27/hidden\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/27/width\",\"Value\":78,\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/27/field\",\"Value\":\"OrderLine\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/28/width\",\"Value\":118,\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/28/field\",\"Value\":\"OrderRelNum\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/28/title\",\"Value\":\"Release\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/29/hidden\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/29/field\",\"Value\":\"ShipViaCode\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/29/title\",\"Value\":\"Ship Via\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/30/hidden\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/30/width\",\"Value\":124,\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/30/field\",\"Value\":\"TermsCode\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/30/title\",\"Value\":\"Terms ID\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/31/hidden\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/31/width\",\"Value\":71,\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/31/field\",\"Value\":\"FOB\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/31/title\",\"Value\":\"FOB\",\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/32/title\",\"Value\":\"Project ID\",\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/32/width\",\"Value\":76,\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/33/title\",\"Value\":\"Description\",\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/33/width\",\"Value\":113,\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/34/erpEditor\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/34/erpEditorModel\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/34/filterable\",\"Value\":null,\"Operation\":\"Remove\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/34/title\",\"Value\":\"Site\",\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/34/width\",\"Value\":107,\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/35/title\",\"Value\":\"Auto Select Error\",\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/35/width\",\"Value\":98,\"Operation\":\"Replace\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/36\",\"Value\":{\"field\":\"ABCCode\",\"title\":\"ABC Code\",\"width\":119},\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/37\",\"Value\":{\"field\":\"Per\",\"title\":\"Per\"},\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/38\",\"Value\":{\"field\":\"ManualFactor\",\"title\":\"Manual Factor\",\"width\":95},\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/39\",\"Value\":{\"field\":\"Factor\",\"title\":\"Factor\",\"width\":141},\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/40\",\"Value\":{\"field\":\"PricingQty\",\"title\":\"PricingQty\",\"width\":106},\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/41\",\"Value\":{\"field\":\"UrgentPlanning\",\"title\":\"UrgentPlanning\",\"width\":64},\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/42\",\"Value\":{\"field\":\"ContractID\",\"title\":\"Contract ID\",\"width\":122},\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/43\",\"Value\":{\"field\":\"EpicorFSA\",\"title\":\"Epicor FSA\"},\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/44\",\"Value\":{\"field\":\"CreatedOn\",\"title\":\"Created On\"},\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/45\",\"Value\":{\"field\":\"CreateApprovedPO\",\"title\":\"Approve PO\",\"width\":146},\"Operation\":\"Add\",\"Index\":1},{\"Id\":\"POSugg_pcgLandingPage\",\"Path\":\"/model/gridModel/columns/46\",\"Value\":{\"field\":\"DropShip\",\"title\":\"Drop Ship\",\"width\":98},\"Operation\":\"Add\",\"Index\":1}],\"Operation\":\"Replace\"},\"events\":{\"Name\":\"events\",\"Version\":\"5.0\",\"Diffs\":[],\"Operation\":\"Replace\"},\"rules\":{\"Name\":\"rules\",\"Version\":\"3.0\",\"Diffs\":[],\"Operation\":\"Replace\"},\"tools\":{\"Name\":\"tools\",\"Version\":\"2.0\",\"Diffs\":[],\"Operation\":\"Replace\"},\"dataviews\":{\"Name\":\"dataviews\",\"Version\":\"4.0\",\"Diffs\":[{\"Id\":\"SugPoDtl\",\"Path\":\"/mode\",\"Value\":\"U\",\"Operation\":\"Add\",\"Index\":5}],\"Operation\":\"Replace\"}}",
