Kinetic PO Tracker Customizations
I have applied a layer to the PO Entry, but I need to apply it to the PO Tracker as well for users that do not have access to PO Entry. When I open Application Studio in PO Tracker, it does not allow me to add any components. I need to add fields to the Tracker for the users that access PO’s through that screen. Any help is appreciated. Thank you.
Nina Richard
You just apply your PO entry layer to the tracker menu item in menu maintenance.
Thank you. I forgot to logout and back in. I did just that and it worked. Problem solved.
