KVM Switches - Daily Failure
D-Link makes decent KVM switches that are priced rather competitively. I
use a d-link 4-port in my cubicle, so I can hook up a workstation, a test
server, and whatever user PC's I happen to be working on at the time. I'd
consider the D-Link to be a reliable product.
We use a Belkin 8-Port in our server rack, and have had no problems.
Thaddeus
Sent: Tuesday, August 06, 2002 7:06 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] RE: KVM Switches - Daily Failure
One last note on the Cybex unit. I hook and unhook computers form this box
all the time without shutting anything down. I usually live in the computer
room and do any computer builds/installs from an unused port on the Cybex.
I shut down the computer I am hooking up but nothing else.
Dave Cole
Reeder & Kline
Sent: Tuesday, August 06, 2002 8:51 AM
Subject: [Vantage] RE: KVM Switches - Daily Failure
Aaron -
Thanks for the tips. I'll try your technique. My only concern is the risk
of unplugging/plugging the cables into a power live box. On the first day I
installed my Belkin, I blew the board in it. Belkin replaced it for me
under warranty but thought it was because I was attaching cables while the
box was powered up.
So short of buying a new Cybex switch that others say has no problem like
this, I'll first try your workaround the next time it fails.
Bob
----- Original Message -----
Sent: Tuesday, August 06, 2002 8:28 AM
Subject: RE: [Vantage] KVM Switches - Daily Failure
Bob, and others that have expressed this is an issue,
Sorry, I was away for the weekend, but I have found the solution to this.
We use a 4 port Belkin on our servers. I had this same keyboard mouse
lockup. The solution is this:
Remove the power cord (if you use it) totally, it uses power from the
computers anyway.
Now when the mouse and keyboard are locked up, unplug the keyboard and
mouse
from the KVM (not the KVM to the computers). Now plug them back in and
move
the mouse and tap cap locks twice on the keyboard (just to be sure the
lights agree). Now right click the mouse and then click outside the
pop-up
(it gets confused with click and right click until you do this). This
works
every time for ours. Sometimes one specific machine will still have a
problem. The answer is to switch to that computer and perform the
operation
above again. You should find functionality comes back. I can't count the
number of times I used VNC to operate my servers before I figured this
out.
Please let me know if I am the only one this works for. If not, maybe we
should clue in Belkin. :)
Good luck,
Aaron Hoyt
Design Standards
Sent: Tuesday, August 06, 2002 7:33 AM
To: Yahoo Group Vantage
Subject: [Vantage] KVM Switches - Daily Failure
I have a UNIX SCO server along with my Vantage PC workstation running
WIN98
2nd Edition. Have used Belkin KVM switch for about 3 years, even before
Vantage install. Great space saving tool!
BUT, periodically through day, my cursor and keyboard on PC lockup and
only
recovery is restart. Belkin says that can happen! No fix? My UNIX
machine
never fails, by the way.
Bob
Yahoo! Groups Sponsor
ADVERTISEMENT
ADVERTISEMENT
<http://rd.yahoo.com/M=228862.2128520.3581629.1829184/D=egroupweb/S=17050071
83:HM/A=1182719/R=0/*http://adfarm.mediaplex.com/ad/ck/990-1736-1039-333>
I have a UNIX SCO server along with my Vantage PC workstation running WIN98 2nd Edition. Have used Belkin KVM switch for about 3 years, even before Vantage install. Great space saving tool!
BUT, periodically through day, my cursor and keyboard on PC lockup and only recovery is restart. Belkin says that can happen! No fix? My UNIX machine never fails, by the way.
Bob
I've noticed with ours (I have two) that if the power is interrupted in any
way to the KVM, the mouse will no longer work on a Windows machine without a
reboot.
Rick
>Bob
We had 3 win 2000 servers on one belkin kvm. Had the same problem with
cursor and keyboard lockingup after about 8 months. We salvaged a couple
old 14" monitors and keyboards and got rid of the kvm.
Mark
Sent: Monday, August 05, 2002 3:10 PM
Bob
Bob,
We also had the same problem with the Belkin KVM. We switched to Cybex and never had the problem again.
Dina
> Bob
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
Dina M. Hieber
Vamco International, Inc.
555 Epsilon Drive
Pittsburgh, PA 15238
(412) 963-7100 - phone
(412) 963-9511 - fax
www.vamcointernational.com
Some of the cheap passive switches work great for the monitors and
keyboards, just use four separate mice to deal with the previously mentioned
hang-ups.
Oleg Tumarkin
Intelligent Systems Integration
(330) 335-5291
olegt@...
"Making Intelligent Use of Technology"
Sent: Monday, August 05, 2002 3:23 PM
Mark
Bob
ADVERTISEMENT
83:HM/A=1182693/R=0/*http://adfarm.mediaplex.com/ad/ck/990-1736-1039-335>
Just last week I had three machines on one Belkin Omni 4 port kvm. Previously I had two (NT & Win2000) but when I added the third (Win 2000 server) the mouse's/mice/rodents would just lock up.
The solution for me was one monitor, one keyboard, three mice/mouse's/rodents.
Looks cool/weird, works good.
Rick
hang-ups.
Oleg Tumarkin
(330) 335-5291
olegt@...
We use the Cybex AutoView Commander 8 port. I have been using it for 4
years and have never had any problems. I had also never seen the problem
where the mouse does not work. This one works by pushing a button or using
a hot key sequence to switch.
Dave Cole
Reeder & Kline
Sent: Monday, August 05, 2002 2:37 PM
Subject: Re: [Vantage] KVM Switches - Daily Failure
Bob,
Dina
> Bob
Dina M. Hieber
555 Epsilon Drive
ADVERTISEMENT
83:HM/A=1182729/R=0/*http://adfarm.mediaplex.com/ad/ck/990-1736-1039-334>
Ditto on the Cybex Autoview Commander 8 port.
About 4 years also ... 5 servers ... ZERO problems ... ROCK solid and worth
the money.
Todd Anderson
J. Rubin & Co.
Sent: Tuesday, August 06, 2002 7:52 AM
Dave Cole
Reeder & Kline
Bob,
Dina
> Bob
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
Dina M. Hieber
555 Epsilon Drive
ADVERTISEMENT
83:HM/A=1182729/R=0/* http://adfarm.mediaplex.com/ad/ck/990-1736-1039-334
<http://adfarm.mediaplex.com/ad/ck/990-1736-1039-334> >
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
<http://rd.yahoo.com/M=231049.2208958.3660596.1829184/D=egroupweb/S=17050071
83:HM/A=1175203/R=0/*http://www.gotomypc.com/u/tr/yh/grp/300_06/g22lp?Target
=mm/g22lp.tmpl>
computers anyway.
Now when the mouse and keyboard are locked up, unplug the keyboard and mouse
from the KVM (not the KVM to the computers). Now plug them back in and move
lights agree). Now right click the mouse and then click outside the pop-up
(it gets confused with click and right click until you do this). This works
problem. The answer is to switch to that computer and perform the operation
number of times I used VNC to operate my servers before I figured this out.
Good luck,
Aaron Hoyt
Design Standards
Bob
Aaron -
Thanks for the tips. I'll try your technique. My only concern is the risk of unplugging/plugging the cables into a power live box. On the first day I installed my Belkin, I blew the board in it. Belkin replaced it for me under warranty but thought it was because I was attaching cables while the box was powered up.
So short of buying a new Cybex switch that others say has no problem like this, I'll first try your workaround the next time it fails.
Bob
computers anyway.
Good luck,
Aaron Hoyt
Design Standards
Bob
ADVERTISEMENT
Dave Cole
Reeder & Kline
Aaron -
box was powered up.
Bob
computers anyway.
mouse
move
pop-up
works
operation
out.
Good luck,
Aaron Hoyt
Design Standards
WIN98
only
machine
Bob
ADVERTISEMENT
ADVERTISEMENT
