When I was finally forced to accommodate Code 128 for Vantage 6.10 I purchased a relatively cheap formula add-in for Crystal and the associated fonts for it. It was not expensive (like $100 or so) and worked great. I don’t recall the vendor (but would if I saw it) and found it via a web search for “Crystal Reports Code 128â€. I don’t think there is a reasonable solution for Report Builder unless you are really familiar with the check-digit calcs required for Code 128.
-Todd C.
Sent: Wednesday, June 25, 2014 10:03 AM
Subject: [Vantage] Labels
Is anyone using Vantage 6.10.543 and is a customer of Caterpillar. What are you using for a labeling software that will work with a 128 barcode. I cant seem to get report builder to work with the 128.
