I have the following code on Labor.Update - Pre-Processing.
This executes fine during the day but at 17:00pm when operators book out I receive deadlock errors.
Is there something wrong in my code or can it be improved to avoid the deadlocks?
/* TO DO: replace object variables with typed variables. Add reference if necessary.*/
object MESSAGE_WARN = null;
decimal doneqty = decimal.Zero;
bool errqty = false;
decimal remqty = decimal.Zero;
string msg = string.Empty;
Erp.Tables.LaborDtl LaborDtl;
Erp.Tables.JobOper JobOper;
Erp.Tables.OpMaster OpMaster;
var ttLaborDtl_xRow = (from ttLaborDtl_Row in ttLaborDtl
where ttLaborDtl_Row.Company == Session.CompanyID && !String.IsNullOrEmpty(ttLaborDtl_Row.RowMod)
select ttLaborDtl_Row).FirstOrDefault();
if (ttLaborDtl_xRow != null)
if (!ttLaborDtl_xRow.EndActivity)
LaborDtl = (from LaborDtl_Row in Db.LaborDtl
where LaborDtl_Row.Company == Session.CompanyID && LaborDtl_Row.ActiveTrans == true && string.Compare(LaborDtl_Row.EmployeeNum, ttLaborDtl_xRow.EmployeeNum, true) == 0
select LaborDtl_Row).FirstOrDefault();
if (LaborDtl != null)
if (string.Compare(ttLaborDtl_xRow.LaborType, "I", true) == 0)
msg = "Indirect \r\nYou are already booked onto Job" + LaborDtl.JobNum + "\r\nAssembly " + System.Convert.ToString(LaborDtl.AssemblySeq) + "\r\nOperation " + System.Convert.ToString(LaborDtl.OprSeq) + "";
CallContext.Current.ExceptionManager.AddBLException(msg);
else
if (string.Compare(LaborDtl.LaborType, "I", true) == 0)
msg = "You are already booked onto Indirect";
else
JobOper = (from JobOper_Row in Db.JobOper
where string.Compare(JobOper_Row.Company, ttLaborDtl_xRow.Company, true) == 0 && string.Compare(JobOper_Row.JobNum, ttLaborDtl_xRow.JobNum, true) == 0 && JobOper_Row.AssemblySeq == ttLaborDtl_xRow.AssemblySeq && JobOper_Row.OprSeq == ttLaborDtl_xRow.OprSeq
select JobOper_Row).FirstOrDefault();
if (JobOper != null)
OpMaster = (from OpMaster_Row in Db.OpMaster
where string.Compare(OpMaster_Row.Company, JobOper.Company, true) == 0 && string.Compare(OpMaster_Row.OpCode, JobOper.OpCode, true) == 0
select OpMaster_Row).FirstOrDefault();
if (OpMaster != null)
if (!(bool)OpMaster["CheckBox01"])
msg = "Multiple Jobs \r\nYou are already booked onto Job" + LaborDtl.JobNum + "\r\nAssembly " + System.Convert.ToString(LaborDtl.AssemblySeq) + "\r\nOperation " + System.Convert.ToString(LaborDtl.OprSeq) + "";
else
if ((ttLaborDtl_xRow.LaborQty - System.Convert.ToInt32(ttLaborDtl_xRow.LaborQty)) != 0)
errqty = true;
if ((ttLaborDtl_xRow.ScrapQty - System.Convert.ToInt32(ttLaborDtl_xRow.ScrapQty)) != 0)
errqty = true;
if ((ttLaborDtl_xRow.DiscrepQty - System.Convert.ToInt32(ttLaborDtl_xRow.DiscrepQty)) != 0)
errqty = true;
if (errqty)
CallContext.Current.ExceptionManager.AddBLException("Enter Quantity with no decimals please");
doneqty = ttLaborDtl_xRow.LaborQty + ttLaborDtl_xRow.ScrapQty + ttLaborDtl_xRow.DiscrepQty;
remqty = JobOper.RunQty;
foreach (var LaborDtl_iterator in (from LaborDtl_Row in Db.LaborDtl
where string.Compare(LaborDtl_Row.Company, ttLaborDtl_xRow.Company, true) == 0 && string.Compare(LaborDtl_Row.JobNum, ttLaborDtl_xRow.JobNum, true) == 0 && LaborDtl_Row.AssemblySeq == ttLaborDtl_xRow.AssemblySeq && LaborDtl_Row.OprSeq == ttLaborDtl_xRow.OprSeq
select LaborDtl_Row))
LaborDtl = LaborDtl_iterator;
doneqty = doneqty + (LaborDtl.LaborQty + LaborDtl.ScrapQty + LaborDtl.DiscrepQty);
remqty = remqty - (LaborDtl.LaborQty + LaborDtl.ScrapQty + LaborDtl.DiscrepQty);
if (doneqty > JobOper.RunQty)
msg = "Booking will exceed Required Quantity of " + System.Convert.ToString(System.Convert.ToInt32(JobOper.RunQty)) + "\r\nBalance Remaining is " + System.Convert.ToString(System.Convert.ToInt32(remqty)) + "";
if (doneqty == JobOper.RunQty)
ttLaborDtl_xRow.OpComplete = true;
ttLaborDtl_xRow.Complete = true;
