Just to follow this up, it's best to enter into the PROENV command prompt
before running this, as well as having the DB stopped.
then type prompt to get to a standard prompt like: e:\epicor\oe101b_wrk>
then browse to your DB location via DOS CD commands
then run the command proutil mfgsys -C truncate bi
where mfgsys is the file name of your DB, assuming you never changed it it
will be mfgsys, no file extentions are needed.
You can work this into a batch file if you want to, but be sure you are
aware these are basically transaction logs you are truncating.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Friday, July 24, 2009 10:00 AM
Subject: RE: [Vantage] Large Backup/B1 file
> Yep, truncate it.
> \\server\epicor\mfgsys803\db\proutil mfgsys -C truncate bi
> Thanks,
> Blake Clemens
> IT Systems Engineer
> Delmarva Millwork Corporation
> (800) 360-2364 x132
> Of Ken Williams
> Sent: Friday, July 24, 2009 9:51 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Large Backup/B1 file
> I'm not sure what happened, but our backup file recently went from about
> 1.2gb to 2.1gb. When I look, it appears the .b1 file has grown from a
> ~100mb to 900mb.
> Any suggestions on how to resolve this? Is this done by the truncate bi
> command I have floating around somewhere?
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
