Linking Access to a .CSV file (exported from Vantage) (WAS: Pro
Do you not use ODBC at all then?
Troy
----- Original Message -----
To: 'vantage@yahoogroups.com'
Sent: Wednesday, January 16, 2002 7:16 PM
Subject: RE: [Vantage] Linking Access to a .CSV file (exported from Vantage) (WAS: Progress/dbf)
In alot of cases, especially with aggregate accounting reports, a day old is
fine.
But in some cases, such as a just-entered BOM, a shortage list that is being
reprinted to verify that a shortage has been eliminated, a bag label for a
part that has just been issued in vantage and needs to be handed to someone
waiting at the shipping gate, real-time data is needed.
Now that I think about it more, until setting up reports on users machines
becomes a real bottleneck, I probably won't even look at the web component
server for use with real-time reports.
Thaddeus
Sent: Wednesday, January 16, 2002 4:01 PM
Subject: Re: [Vantage] Linking Access to a .CSV file (exported from
Is your concern with the file being locked that a user may try to access a
report on the WCS at the same time as the export is happening? You must
want to do multiple exports during a day. In our case, the export happens
overnight when no one is on. I've never had a user need more current data
than that on our few exported reports. In your case, if you're talking
about exporting ALL of your reports (to eliminate ODBC completely), then I
could see where you may need to work out the locking files situation.
Out of curiousity... What kind of reports are you wanting to deploy this way
(via export-access-crystal on each machine)?
Troy Funte
Liberty Electronics
Sent: Wednesday, January 16, 2002 6:47 PM
The approach I'm going to be using is probably this:
1)write a progress program that exports necessary records to CSV file(s)
in
the vntgwrk directory, copies the linked access database to the vntgwrk
directory, and launches an EXE file.
2) the EXE file will be a crystal report bundled in a visual basic
application, in some cases the application will contain multiple reports,
and code to export to Excel.
3) The crystal report will be connected to the linked Access-CSV query.
The above approach allows me to use a pretty minimal amount of code for
simple reports, though if I want, I have the flexibility of manipulating
records in progress or visual basic before the crystal report is run.
With this approach, though, comes deployment issues. You have to setup at
least one bundled report on every machine so the user has the appropriate
dll's. I've run into problems with this when distributing report packages
over multiple operating systems. We've just made the determination that
all
report users have windows 2000, so distribution shouldn't be too
difficult,
though installing on every machine is a step worth eliminating.
If in the CSV export code there was a way to wait until there no lock on
the
file to export it, and some sort of way to tell crystal component web
server
to wait until the export is finished before refreshing, you could then
safely have a crystal-access-CSV report deployed over the crystal
component
web server for multi-user use.
Then, for my intents and purposes, OBDC would be history.
I would appreciate any questions or comments on my reporting methods, as I
am trying to improve them to be as programmatically flexible and efficient
as possible, as well as cost effective.
~Thaddeus
Sent: Wednesday, January 16, 2002 3:15 PM
Thad,
I just did a quick check. With Crystal Opened and viewing data, I can
open the .csv file in Excel with no problem. However, with the .csv file
open in Excel, I can't refresh the Crystal report until Excel let's go of
the file.
So, Excel definitely locks the file. I would think that Crystal locks the
file only while it is reading the file to refresh, and then releases the
file.
Troy
Sent: Wednesday, January 16, 2002 5:35 PM
Troy,
If a user has one of these Crystal-Access-CSV reports opened, is the CSV
file locked in anyway, based on your experience?
Thaddeus
Sent: Wednesday, January 16, 2002 2:24 PM
Subject: [Vantage] Linking Access to a .CSV file (exported from Vantage)
(WAS: Progress/dbf)
There are several steps to linking Access to a .CSV file and running a
Crystal Report against it. Once set up, however, you can simply export
the
.CSV to the same file name, and then run the Crystal Report. (NOTE:
This
was all done in Access 2000. I can't vouch for other versions of Access
and
how they handle long fields like "PartDescription").
1. Export the .csv file. I'll assume it's called "c:\vntgwork\PO.CSV".
2. Open Access to a new blank database and give it a meaningful name and
path.
A. Click File/Get External Data> /Link Tables...
B. Select File type "Text Files (*.txt;*.csv;*.tab;*.asc), then find
"c:\vntgwork\po.csv", click Link.
C. Walk through the wizard. If you put Field names at the top,
check
that box.. etc. Click Next, Click Finish.
D. With the new PO table selected, Click the Queries Button.
E. Click "Create Query by using Wizard"
F. Select all fields show (if desired), then click Next, Next,
Finish
(if you like the name offered "po query".
3. Open Crystal Reports.
A. Click on File/New/ ... As Blank Report
B. In Data Explorer, Click Database Files.
-- If you see your Access File ?.mdb, then double-click.
-- If you don't see your Access File, click "Find Database File"
and
find it.
C. Once you double-click on your file, you should see the "PO
Query"
that you created in Access.
D. Select the query just like you would a Vantage table. Click Add.
Click Close.
E. You can link multiple queries from other Access tables if
desired.
F. You should now see the fields in the table just as you do with a
Vantage Table.
G. Create your report.
NOTE: By update your .csv file, your Crystal Report will automatically
see
the new data the next time you refresh it.
Have Fun.
Troy Funte
Liberty Electronics
Sent: Wednesday, January 16, 2002 4:05 PM
Subject: RE: [Vantage] Progress/dbf
>Let me know if you want to see how to do it.
I'm all ears!
Sent: Wednesday, January 16, 2002 12:48 PM
Subject: Re: [Vantage] Progress/dbf
I'm not sure what you are hoping to do, but I link .csv files in
Access
all
the time, and then run Crystal Reports off the .csv. We also have an
extensive Excel-based program that runs off our .csv files
automatically.
Let me know if you want to see how to do it. We just update the .csv
files
nighty using the progress export like you are and Crystal is ready to
be
run
off the Access database that is Linked to the .csv files.
These reports run much faster than through ODBC/Progress, which is why
we're
doing it. Speed. (Translated seconds compared to hours).
Troy Funte
Liberty Electronics
Sent: Wednesday, January 16, 2002 12:29 PM
Subject: [Vantage] Progress/dbf
This 4GL coding newbie was hoping that changing my exports to dbf
from csv would be as simple as changing the file extensions. Sure.
I've found some information in the Files section on Progress and
dbf,
but I'm relatively sure that I'm not ready for that. Second
"stretch"
of the day. Is there a way to setup a .P file that will run an
export
that was created using the export utility? These dbf files are to be
linked to MS Access. I don't want to use ODBC, and I don't want the
end user to have access to the export utility. Any words of wisdom?
Les Tingley
MIS
Decorated Products
Yahoo! Groups Sponsor
ADVERTISEMENT
Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
must
have already linked your email address to a yahoo id to enable access.
(1) To access the Files Section of our Yahoo!Group for Report
Builder
and
have
and
http://docs.yahoo.com/info/terms/
ADVERTISEMENT
and
have
and
and
have
ADVERTISEMENT
ADVERTISEMENT
There are several steps to linking Access to a .CSV file and running a Crystal Report against it. Once set up, however, you can simply export the .CSV to the same file name, and then run the Crystal Report. (NOTE: This was all done in Access 2000. I can't vouch for other versions of Access and how they handle long fields like "PartDescription").
2. Open Access to a new blank database and give it a meaningful name and path.
B. Select File type "Text Files (*.txt;*.csv;*.tab;*.asc), then find "c:\vntgwork\po.csv", click Link.
C. Walk through the wizard. If you put Field names at the top, check that box.. etc. Click Next, Click Finish.
F. Select all fields show (if desired), then click Next, Next, Finish (if you like the name offered "po query".
-- If you don't see your Access File, click "Find Database File" and find it.
C. Once you double-click on your file, you should see the "PO Query" that you created in Access.
D. Select the query just like you would a Vantage table. Click Add. Click Close.
E. You can link multiple queries from other Access tables if desired.
F. You should now see the fields in the table just as you do with a Vantage Table.
NOTE: By update your .csv file, your Crystal Report will automatically see the new data the next time you refresh it.
Have Fun.
Troy Funte
Liberty Electronics
I'm all ears!
I'm not sure what you are hoping to do, but I link .csv files in Access all
extensive Excel-based program that runs off our .csv files automatically.
Let me know if you want to see how to do it. We just update the .csv files
nighty using the progress export like you are and Crystal is ready to be run
These reports run much faster than through ODBC/Progress, which is why we're
Troy Funte
Liberty Electronics
I've found some information in the Files section on Progress and dbf,
but I'm relatively sure that I'm not ready for that. Second "stretch"
of the day. Is there a way to setup a .P file that will run an export
Les Tingley
MIS
Decorated Products
ADVERTISEMENT
ADVERTISEMENT
Thad,
I just did a quick check. With Crystal Opened and viewing data, I can open the .csv file in Excel with no problem. However, with the .csv file open in Excel, I can't refresh the Crystal report until Excel let's go of the file.
So, Excel definitely locks the file. I would think that Crystal locks the file only while it is reading the file to refresh, and then releases the file.
Troy
Troy,
Thaddeus
(WAS: Progress/dbf)
path.
find it.
Click Close.
Vantage Table.
Have Fun.
Troy Funte
Liberty Electronics
I'm all ears!
all
files
run
we're
Troy Funte
Liberty Electronics
Les Tingley
MIS
Decorated Products
ADVERTISEMENT
and
have
ADVERTISEMENT
Is your concern with the file being locked that a user may try to access a report on the WCS at the same time as the export is happening? You must want to do multiple exports during a day. In our case, the export happens overnight when no one is on. I've never had a user need more current data than that on our few exported reports. In your case, if you're talking about exporting ALL of your reports (to eliminate ODBC completely), then I could see where you may need to work out the locking files situation.
Out of curiousity... What kind of reports are you wanting to deploy this way (via export-access-crystal on each machine)?
Troy Funte
Liberty Electronics
1)write a progress program that exports necessary records to CSV file(s) in
over multiple operating systems. We've just made the determination that all
report users have windows 2000, so distribution shouldn't be too difficult,
If in the CSV export code there was a way to wait until there no lock on the
file to export it, and some sort of way to tell crystal component web server
safely have a crystal-access-CSV report deployed over the crystal component
~Thaddeus
Thad,
the file.
file.
Troy
Troy,
Thaddeus
(WAS: Progress/dbf)
the
and
path.
and
find it.
Click Close.
Vantage Table.
see
Have Fun.
Troy Funte
Liberty Electronics
I'm all ears!
all
automatically.
files
run
we're
Troy Funte
Liberty Electronics
Les Tingley
MIS
Decorated Products
ADVERTISEMENT
and
have
and
ADVERTISEMENT
and
have
ADVERTISEMENT
