Linq differences
I know this isn’t stack overflow but I figured since we are in the same world of LINQ, SQL and DBs I would pose this question.
What are the fundamental differences between the following bits of code? Do they both have deferred datasource access?
 var numQuery =
                numbers.Where(num => num % 2 == 0);
vs
 var numQuery =
            from num in numbers
            where (num % 2) == 0
            select num;
@josecgomez come on, be my Jon Skeet
There is no practical difference. One is just a lambda implementation
Jos? C Gomez
Senior Software Engineer
Jos? C Gomez
@Chris_Conn yes, they are both deferred execution. For immediate execution a query would be something like below or the use of an immediate operator (count, sum, etc.). The deferred execution is the better way to go for performance.
var emp = Employees.Where(x => x.Salary < 35000)
	  	   .Select(y => y.Name).ToList();
