Hello - I’m having an issue with authentication and am using Windows endpoint binding. How can I specify which user account to use?
void Main()
// Change query references to point to the correct Ice.Data.Model.dll and Erp.Data.910100.dll from your server directories (Press F4 or Edit the .linq file).
// Change this to point to your server web.config file
var webConfigFile = @"\\E10Server\c$\inetpub\wwwroot\ERP10_Test\Server\web.config";
InitialiseConfiguration(webConfigFile);
// Enable for 10.2 Only
EpiProviderRegistrator.Register();
var Db = new ErpContext();
Db.Part.Where(p=>p.Company == "1000" && p.PartNum == "American Legends").Dump();
private void InitialiseConfiguration(string webConfigPath)
// Resetting is based on http://stackoverflow.com/questions/6150644/change-default-app-config-at-runtime
AppDomain.CurrentDomain.SetData("APP_CONFIG_FILE", webConfigPath);
typeof(ConfigurationManager)
.GetField("s_initState", BindingFlags.NonPublic |
BindingFlags.Static)
.SetValue(null, 0);
.GetField("s_configSystem", BindingFlags.NonPublic |
.SetValue(null, null);
.Assembly.GetTypes()
.Where(x => x.FullName ==
"System.Configuration.ClientConfigPaths")
.First()
.GetField("s_current", BindingFlags.NonPublic |
//ConfigurationManager.ConnectionStrings.Dump();
