Load more than the capacity
We are running into the same issue i have logged a call and Deb Nolen is working on it. we are running Global and MRP every night with finite scheduling and it is still overloading and under loading resources be aware that it will also push the scheduling of your resources past your ship date if it feels the need. the call log is 5389713MPS--- In vantage@yahoogroups.com, Sreejith Jaganathan <sreesvantagedoubts@...> wrote:
> Friends;
> We are facing a problem after running the MRP Process.Â
> We assign the required by date on the Sales Order as per the priority given by each customer in each month. We manually created the jobs for each order and did the scheduling manually. We are having approximately 1750 jobs per month so it is not possible to do the scheduling manually.Â
> In doing the scheduling manually we found that the capacity and the load is approximately getting balanced but found it to be a very tiresome activity.
> We tried MRP. After finishing with the MRP job suggestions were given by the system. When we see the shop load report we found that on some days the load is more than the capacity and on some days the load is very less in comparison to the capacity.
> We would like to know is there any way to get back to back scheduling. What we mean is that is there any way so that we don't get the load to be more than the capacity; if any such situation come thenÂ
> 01. We should be informed about the overload
> 02. The system should automatically shift the excess load onto the next day.
> Hope that I had been able to present my query clearly to you. If any further information required please feel free to mail me.
> An immediate reply to this issue would be of a great help.
> Regards
> Sreejith J
Friends;
Regards
Sreejith J
