Is it possible to get part description for a part number when pressing the TAB key for a UD field?
I have used EpiBinding: CallContextBpmData.Character01 and CallContextBpmData.Character02 for my 2 textboxes and added a simple search button.
Instead of pressing the search button and waiting for the window to open,let’s say that I type the part num, and if it exists in the DB when TAB key is pressed, I’d like to also retrieve the part description…
You can use the simple search option in a customization and a validate event to trigger the search. I’ll see if I can find some code to throw together for ya
-Jose
// On top within your class Script add
EpiTextBox txtKeyField;
// Inside your InitializeCustomCode() add
// you might need to change the actual key fields GUID
this.txtKeyField = ((EpiTextBox)csm.GetNativeControlReference("46567b2e-6bc0-4967-be35-a0ec6843838f"));
this.txtKeyField.KeyDown += new System.Windows.Forms.KeyEventHandler(this.txtKeyField_KeyDown);
// Inside your DestroyCustomCode() add
this.txtKeyField.KeyDown -= new System.Windows.Forms.KeyEventHandler(this.txtKeyField_KeyDown);
// Add this code to your Customization
// modify it as needed with extra checks etc...
private void txtKeyField_KeyDown(object sender, System.Windows.Forms.KeyEventArgs args)
if (args.KeyCode == Keys.Tab | args.KeyCode == Keys.Enter)
string key1 = String.Empty;
string key2 = String.Empty;
string key3 = String.Empty;
string key4 = String.Empty;
string key5 = String.Empty;
key1 = this.txtKeyField.Text;
// Call Adapter method
bool result = this.oTrans.GetByID(key1, key2, key3, key4, key5);
if (!result)
DialogResult dialogResult = EpiMessageBox.Show("Record does not exist, would you like to create a new one?", "New Record?", MessageBoxButtons.YesNo);
if ((dialogResult == DialogResult.Yes))
if (this.oTrans.GetNew())
//this.txtKeyField.Text = key1;
EpiDataView edvOEM = this.oTrans.Factory("UD100");
edvOEM.dataView[edvOEM.Row]["Key1"] = key1;
this.oTrans.Update();
