Loading Dataview from rest-erp action
Trying to load UDCodes into a dataview. I see the data coming back from the REST call but not able to get it into the dataview.
1 - Created the view.
2 - Specified the service call.
3 - Configured the Method Parameters.
4 - Configured the Response Parameters.
5 - Trigger the method and can see the response data.
6 - Confirmed my EPBinding on the Grid Model.
The data view remains empty.
Try using guided setup? It does pretty well at this.
I think I got it figured out but don’t really understand the Why’s of how I got it working.
I opened up User Codes Maintenance in App Studio and looked at how the data view was defined there.
I looked at the method parameters for the REST call.
I then returned to the form that I was working on, deleted the action and re-added it. Only thing I did different is I filled in the Dataset information the sames as it is in User Code Maintenance.
I am getting data loading into the view now.
I think some of the posts I was initially looking at may have been designed to get around previous bugs. The key is probably the way I setup the Dataview the second time. If you fill in the server side dataset and table, it should map the response dataset and tables correctly (I guess).
This solution is working.
