--- In vantage@yahoogroups.com, "jfmartin67" <johnmartin@...> wrote:
did the same thing for report data defs too
>When I was tasked with setting up a db for another company, I used the data adminstration tools in Open Edge to dump the table contents for certain GL tables and then imported the data in the new db
> just started a blank db (in pilot) to build up for 905.606. going through system setup instructions (and copying certain information over from our current live db - also 905.606.
> but have gotten to gl control types. there is no base information already there for gl control types. can't copy the information from the current live db.
> is there a conversion to run or some other way (instead of manually typing 35 records) to get the gl control types set up/loaded into this new db?
