Vantage just uses the vntgwork folder like a temporary folder when doing reports, etc. But it leaves the files there when it is done. They can be safely deleted, as Vantage makes them again the next time anyway. (The exception is the cache file as Ted mentioned, which you can recreate using the Vantage menu. It doesn't hurt anything by deleting the cache file. Vantage can work without it. It is just a time-saving feature.)
Troy
Troy
----- Original Message -----
To: vantage@egroups.com
Sent: Thursday, December 14, 2000 12:34 PM
Subject: [Vantage] Local Vntgwork folder
Local working directory for Vantage...
What can be deleted out of here? I have an individuals that is fairly
large and he doesn't have much disk space to spare. Mine is over 7
MB. I know that I have copied the contents of other peoples folder to
mine when I have tried to edit crystal reports that I do not have access
to. It allows you to view the reports without getting all of the
errors. Can anyone tell me what each file type does and which can be
deleted?
Juliet Martin
eGroups Sponsor
We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
