Lock Qty checkbox on po release
Using Vantage 8.03.405a
I went through all kinds of gyrations to implement this in a UI customization - without success. I tried basic BPMs to do this - without success. Because of the way the first release is automagically created by the progress code on the server backend and the lock qty / date fields not actually residing in the PORel table, I had to come up with a complex set of BPMs that rely on the open edge developer license to make it work with any kind of reliability...
bw
--- In vantage@yahoogroups.com, robertb_versa@... wrote:
> Good luck. It's not part of PORelease. They stash it in the xref table (making it tough to manipulate).
> I suppose you could replace the native chkbox w/ your own & link it to the apps dataview. Then (w/ some vbcode & a reliable event trigger) push TRUE into your control's state & try an otrans.update.
> Maybe someone out there has a way (that could also be applied to date locking).
> Rob
> --- Original Message ---
> From:"Rick" <rhagy@...>
> Sent:Wed 8/25/10 2:02 pm
> To:vantage@yahoogroups.com
> Subj:[Vantage] Lock Qty checkbox on po release
> Does any one know how to have this box checked all the time?
Rob
