Hello,
I am trying to write a BPM that stores the WorkStation (ComputerName) either into the LaborHed Table UD fields or write a log into a UDtable.
EmpBasic.ClockIn and EmpBasic.ClockOut seem to be the best Method Calls to work with, but there is no ttTables.
Do I need to do this in CustomCode or is there a way to write to the LaborHed or UD10 table using the BPM tools?
Thanks in advance for any advice,
Chris
@Cnelson Welcome. You have the employeeID and from there you just need the top1 descending laborhed to update. Session.ClientComputerName should hold the name. I don’t know about widgets, but in code this would be relatively simple.
Thank you. I was able to store that a variable and utilize the tools within the BPM to write that info to a UD table.
