Hi all,
I’m getting the following entries in my Epicor905Server.log can anyone tell me what they are and should I be concerned
There doesn’t appear to be any issues with the system generally, although every now and again we have work orders that don’t appear on the schedule, and I need to manually schedule them by going into Job Entry and doing Actions / Schedule.
Looking at the JobHead table is sql Field 47 is WIStartDate which appears in most cases to be populated although there a few will NULL in.
John
[17/08/17@13:41:06.329+0100] P-009772 T-010220 1 AS -- (Procedure: 'WriteJob es/SchedEngine.p' Line:87398) Field 47 of table JobHead not in buffer. (4176)
[17/08/17@13:42:15.509+0100] P-009772 T-010220 1 AS -- (Procedure: 'WriteJob es/SchedEngine.p' Line:87398) Field 47 of table JobHead not in buffer. (4176)
[17/08/17@13:42:50.543+0100] P-006396 T-008272 1 AS -- (Procedure: 'WriteJob es/SchedEngine.p' Line:87398) Field 47 of table JobHead not in buffer. (4176)
[17/08/17@13:43:44.328+0100] P-009772 T-010220 1 AS -- (Procedure: 'WriteJob es/SchedEngine.p' Line:87398) Field 47 of table JobHead not in buffer. (4176)
[17/08/17@13:44:26.108+0100] P-000528 T-010328 1 AS -- (Procedure: 'WriteJob es/SchedEngine.p' Line:87398) Field 47 of table JobHead not in buffer. (4176)
[17/08/17@13:46:02.931+0100] P-009772 T-010220 1 AS -- (Procedure: 'WriteJob es/SchedEngine.p' Line:87398) Field 47 of table JobHead not in buffer. (4176)
[17/08/17@13:46:34.800+0100] P-009772 T-010220 1 AS -- (Procedure: 'WriteJob es/SchedEngine.p' Line:87398) Field 47 of table JobHead not in buffer. (4176)
[17/08/17@13:46:52.653+0100] P-006396 T-008272 1 AS -- (Procedure: 'WriteJob es/SchedEngine.p' Line:87398) Field 47 of table JobHead not in buffer. (4176)
[17/08/17@13:49:12.708+0100] P-006396 T-008272 1 AS -- (Procedure: 'WriteJob es/SchedEngine.p' Line:87398) Field 47 of table JobHead not in buffer. (4176)
