I’ve working reading a lot about bit shifting and trying to figure out if a bit is active.
Interesting to see that Epicor 10 makes this a little simpler.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
addr: 37 Shuman Ave | Stoughton | Ma | 02072-3734
jrojas@... | www.matsinc.com
Ask us about our clean, green and beautiful matting and flooring
[cid:f9a084.png@08a38dc7.49a5fdf6]
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Sent: Monday, June 09, 2014 7:06 AM
Subject: [Vantage] RE: Logic behind BitFlag field
Hi Joe,
See details here for how it works, you are on the right lines
http://www.dotnetit.co.uk/blog/article/epicor-erp-bitflag-logic-technical
hope that helps
regards,
Sent: 06 June 2014 21:10
Subject: [Vantage] Logic behind BitFlag field
Hi All,
I was trying to figure out how the order entry UI knew if there was a Memo associated with the order/line/release.
It looks like the BitFlag field is used to indicate this.
Does anyone know what the logic is behind this field? It contains a number and I suspect it uses bit logic to calculate its value but I’m wondering how I can determine if the bit to indicate that a memo exists is active.
jrojas@...<mailto:jrojas@...> | www.matsinc.com<http://www.matsinc.com>
[cid:15937c.png@7eb0d355.4fa09f16]
Stephen Edginton (Beng) | Solutions & Technical Director
Mobile:
+44 7734 858415
Main:
+44 (0) 121 314 1170
Web:
www.dotnetit.co.uk<http://www.dotnetit.co.uk>
Dot Net IT Limited, One St Kenelm Court, Steel Park Road, Halesowen, B62 8HD, United Kingdom.
[Image removed by sender. DotNetIT]
[Image removed by sender. Epicor Platinum Partner]
[Image removed by sender. Epicor Alliance Partner]
